amp ground
Old Jan 20, 2003 | 11:00 AM
slamm3d91's Avatar
amp ground
where should i ground my amp to make it work properly where i have it ground i hear motor noise. i want to get it fixed so it is workin properly. so ne good suggestions.
thanx
matt
Old Jan 20, 2003 | 01:53 PM
89BlueCamarO's Avatar
where is your amp located? I have my amps on an amp rack that on top of the gas tank, they are grounded in the spare tire well. Make sure to take sand paper and clean off the surface to be grounded on for the best contact.
Old Jan 20, 2003 | 02:05 PM
IROC350TPI's Avatar
Car: 89 IROCZ28
Engine: 350TPI
Axle/Gears: 2.77 Gears
I've got my amp in the back well area and I ran my ground wire to the top support for the rear seatbelts. Just loosened up the bolt, crimped on a butt connector and snipped the tip off so it would go around the bolt and tightened it back down. Haven't had any problems with noise at all.
Ryan
Old Jan 20, 2003 | 02:32 PM
theSteve's Avatar
Car: 1985 Trans Am
Engine: upgrading...
Transmission: upgrading...
Ryan
thats beaut! so fresh and so clean. i like it!
Old Jan 20, 2003 | 03:04 PM
slamm3d91's Avatar
i have mine connected in the spare tire well and i get a motor noise. when i hit the gas it gets louder and i can only hear it when the music is turned all the way down but i will try the seat belt and c how that works
thanx matt
Old Jan 21, 2003 | 09:10 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Ryan
I love that setup! Beautiful and clean! What are you pushing with it? Is the sub under there?
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
