gta amp
Old Jan 23, 2003 | 07:13 PM
87TAGTACANADA's Avatar
gta amp
Did all Pontiac GTAs come with a built in amp?
Old Jan 23, 2003 | 07:21 PM
patrickm00's Avatar
nope. mine didn't. i think they actually discontinued it sometime in '88, so actually a lot of them don't, but i think a majority of 87's probably do.
Old Jan 23, 2003 | 08:14 PM
Mine is an 87 ,are the amps anygood or should i replace it ?and what would fit in the same spot?
Old Jan 24, 2003 | 10:34 PM
patrickm00's Avatar
well, i guess the question is how do you think it sounds? the stock amp is about 2x25 W rms, so it's not too bad for basic speakers. it might be simpler to get a new set of 4x6's for the back, see how that sounds, and if you don't think it's good enough then, move the 4x6's to the front, then swap the stock back speakers for 6x9's. you can get the mounting plates with the 6x9 holes from any junkyard, since 90% of f-body cars have them. just take the trim panels off, and there's four bolts or so holding it to the sail panel.
HP52TA
Feb 3, 2018 10:51 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
gta892000
Sep 16, 2015 12:37 AM
okfoz
Sep 15, 2015 05:22 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
