Cement Box???
Old Jan 24, 2003 | 10:13 AM
Supercharged84Z's Avatar
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
Cement Box???
my friend was talking to me about what some guy was talking to him about...he said that this guy used a CEMENT box and used a 6 1/2 inch sub and blew away everyone else at a comp, but wouldnt a cement box weigh about 100 pounds??...when i asked WHY THE F**K WOULD ANYONE DO THAT?!?! he said it seals better..my question is has anyone ever heard of doing this or done this? i dont know what cement has that good ol' MDF with a little silicon doesn't...:lala:
Old Jan 24, 2003 | 10:30 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Well...... that would be some "HEAVY" bass. LMAO!!!!! :sillylol:
Seriously, I don't think it would be worth it, although I can see why it would help. The cement has no resonance or flex at all. That means you would have 100% (or damn close) pure music coming out of that box.
I guess if you wanted to experiment, you could try sheet rock. It would weigh a little less and still be pretty solid. Then maybe use cement caulk to seal it??? I dunno.....
Old Jan 24, 2003 | 11:38 AM
jawzforlife1's Avatar
How much is 3/4" MDF going to flex?? I use about 2 guns of Liquid Nail in each box I make, This in no open gaps on that.
Old Jan 24, 2003 | 11:58 AM
AJ_92RS's Avatar
By flex I mean resonate. If you hit the box with your knuckes, and put your ear next to the hole you made for the speaker, you can hear a slight "ring". Granted, it doesn't last for long, but it's there. That's what's known as resonance. The box has a certain frequency it likes, and will either compliment the speaker , or fight with it at that frequency.
If you do the same to a concrete box (it sounds weird even saying those two words together ) you won't hear as much of a ring, if any at all (depending on how thick the concrete is). It would be a dead box, which in reality is what you actually want.
I wouldn't worry about it. Any resonance that is overcome by using a box like that will be very hard to notice in a car. The car itself has a resonance frequency. That's what Dynomat and similar products are made to reduce.
Then there's the accoustical properties of a car, but I won't get into that. It has nothing to do with what a box is made of.
Old Jan 24, 2003 | 12:47 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
yeah unlike what your friend said, a concrete box has nothing to do w/ sealing. a mdf box could be sealed almost as good. it just the resonance property of concrete that makes the difference. i do not think it would be worth it unless the vehicles sole purpose was for spl. otherwise it would feel like you were driving go kart. weight is the main issue.
Old Jan 24, 2003 | 12:59 PM
It all makes sence know
Old Jan 24, 2003 | 01:22 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
well if your going for resonance why not make a steel box? i got the metal and a new mig welder. hell it will resonate better then any wood.
Old Jan 24, 2003 | 02:50 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
the point is you DONT want the box to resonate. plus, concrete is less porous than mdf. granted, mdf leaks nothing noticable to most people, but you gotta recognize that spl competitors (especially the expert classes) are trying to get the most out of their equipment. to them, every tiny bit helps. but for me, i'll stick with fiberglass and 3/4" mdf
Old Jan 25, 2003 | 12:04 AM
underdave's Avatar
Car: '91 Firebird vert
Engine: 305 TBI
Transmission: auto
Re: Cement Box???
must have been a crappy ghetto competition if he killed everybody with a 6.5" speaker.
i think you're being lied to
Old Jan 25, 2003 | 10:03 AM
Engine: 350 CID
i just cant imagine why someone would want to go through the trouble to make a freakin cement box when you can get basically the same results from a wood box
Old Jan 26, 2003 | 11:10 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
don't use sheet rock. itz weaker than mdf. u can also use hdf, but the problem is that it is alot harder to work with, instead of splittin it will chip and then u have to start alll over
Old Jan 27, 2003 | 08:10 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Right. Maybe next he'll enter an SPL contest with a truck full of tweeters.
When your friend knows a guy that slept with a guy's sister that had a roomate who new a guy that did something... chances are it's crap.
Old Jan 27, 2003 | 09:08 AM
Engine: 350 CID
ROTFL HAHA THAT MADE MY DAY...but anyway, i dont know what to think..i think the guy is just
Old Jan 27, 2003 | 10:04 AM
HamSpiced's Avatar
yea? well my best friends third cousins nephews sisterinlaw has a boyfriend that made a box out of lead and blew away the red-neck family reunion with a 5" paper coned sub!
Old Jan 30, 2003 | 03:25 AM
89-28gp's Avatar
Car: 1986 Firebird
Engine: not stock 2.8
i almost fell off my chair laughing when i read that. that's almost as wild as one suggestion i got; packing tape seal the box your sub comes in & mount it in there, a real cool cheap box
Old Jan 30, 2003 | 11:05 PM
mcss383's Avatar
Actually, a metal box wouldn't be bad for a full out SPL system (SUCK for everything else though). You don't want the box absorbing any of the energy, you want it all reflected out, thick steel would do that pretty well.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
