TOP PLATE only Now!
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
TOP PLATE only Now!
i recently built a dual 10 box to fit my 3rd gen and have 2 mtx 6000's in it. it sounds pretty good but since the well of our cars acts as a sealed box with the right top plate anyway im just going to rebuild a top plate for it and then cut out 12 inch holes to out some serious shove in my car. has anyone ever done anything like this and if so how does it sound??? does it seal correctly? this will also help me out a lot my saving a little more weight out of our 5 trillion pound cars!
Car: 89 Camaro RS
Engine: 2.8L V-6
build an actual box, you'll be glad you did. Dont use a baffle aka top plate unless they are specifically free-air subs. Just putting a baffle there wont seal well enuf to have the subs perform like they should.
Car: 1991 Z28
Engine: 383
ive got my dual 10 box already built but i just needed to know frtom someone whos done this b4 if it worked. i just couldnt seem to build my box to be able to fit 2 12's unless the had very small magnents because of the way our well slants down!! any tips?
Car: 89 Camaro RS
Engine: 2.8L V-6
You couldnt fit 2 12"? Thats crazy, ask anyone on the board how they did it... lots of peeps have 2 12". I have one (soon to be 2) and they will fit in my box i have now. and alpines arent the smallest subs. Surely you can figure it out.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I've got my one 12" Pioneer like that.
Before the Pioneer, I had one 12" MTX Thunder3000 in there and hit 135.5 dB with a Punch 100 pushing it.
IMO the Pioneer sounds better. It's louder of course because it's a 4 ohm where the MTX was an 8 ohm (got it cheap)
Regardless, it sounds better. Better quality.
Regardless, it sounds better. Better quality. TGO Supporter
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Plates suck. Hard. It will not be sealed no matter how badly you want to think otherwise. There will be MASSIVE amounts of air leaking around all of the plastic panels. The ONLY part that seals half decent is the part that faces toward the front. Everything else seals about as well as a screen door in a hurricane.
There's no reason why you can't fit a pair of 12s in a conventional box. Plenty of us have that type of configuration here.
But even if for whatever reason you can't.... I'd happily take 1 10 in a box over 2 12s in a plate. It'll play louder, and sound a ton better. I've had every type of thirdgen install you can imagine, and I can say without hesitation that a plate is by far the worst of any configuration.
Car: 00 TA, 91 Formula, 89 RS
1992 Trans Am
May 10, 2023 07:19 PM
gixxer92
Sep 1, 2015 04:32 PM
