Power Antenna
Old Feb 11, 2003 | 03:23 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
Power Antenna
Can anyone help me find a replacement power antenna for my Camaro? I need one with a black mast. Crutchfield can't help me out and all I could find on E-Bay are chrome mast ones. Thanks in advance.
Old Feb 20, 2003 | 07:38 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
www.mcmelectronics.com (800)543-4330
MCM part#61-365 $59.95 It says Black version.
Never mined, discontinued.
Old Feb 20, 2003 | 10:59 PM
25THRSS's Avatar
couldn't you just buy one from the dealer?
Old Feb 22, 2003 | 12:00 AM
25THRSS's Avatar
or are they discontinued
Old Feb 25, 2003 | 06:38 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
you dont need one out of a camaro necessarily, i got mine out of a delta 88! works fine! i would suggest going to a junkyard and asking at the counter if they have any from an early model GM. Just take your PA motor and compare them. if it looks the same and has the same wires, it will more then likely work.
Old Feb 26, 2003 | 12:56 AM
25THRSS's Avatar
what is needed to go from a fixed mast antenna to a power antenna?
Old Feb 26, 2003 | 01:09 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i want to switch to a power antenna because it looks better parked. not quite as nice as a shaved antenna, but still allows you to get radio reception.
Old Feb 26, 2003 | 04:32 PM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
is there a way to from a normal antenna to a power antenna?
Old Feb 26, 2003 | 05:45 PM
Car: 1984 Z28
its pretty easy, there is a relay that you will need, its on the passenger side under the dash. it has a green white and grey wire going into it, and a pink and orange wire going out (into where you would put a cd player or whatever) take this relay with all the wiring, get the power antenna, usually early model GMs have pretty much the same antenna. You would need to make some type of mounting system (unless where the regular antenna is, you can mount it where that one is mounted) also, when you get the relay, look in the fender where the antenna would be and try to find a bracket that looks like a "Z" i guess. once you have these its pretty easy.
Green wire - hooks to green on antenna
white - white
grey - grey
i belive the pink one is power and the orange is ground.. one of the two.
if you need furthuir help dont hesitate to pm me.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
