sub noise
Old Feb 23, 2003 | 09:47 PM
1989TransAm's Avatar
sub noise
i've had really bad sub noise before (a Bazooka tube), i had the RCA cables run under the dash by all the other electrical, i decided to move it and run it under the carpet of the driver side foot area. it went away...for a week. the sound is back. my current setup is running it under the carpet, under the plastic runners on the side going through the rear where the 6x9s are under the little plastic arm rest, and then going to the back. what can i do to solve the sound problem. it goes on when the radio and cd are in, and it stays on even when i put the volume all the way down. what could the problem be? they're monster rca's...or can it be the power cables?...these are run on the right side of the car the positive straight from the batt. negative to bare metal in the trunk. any help would be appreciated thanks. btw...everything is Monster.
Old Feb 23, 2003 | 09:50 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Check all your gounds.
They are the most likely culprit....
Old Feb 24, 2003 | 11:52 AM
Eric86TA's Avatar
Yes, check you grounds, all of them. If the noise changes pitch when you motor is a different RPM's thenb check you motot ground strap.
Old Feb 24, 2003 | 01:21 PM
no eric, it's not noise like that, its a constant loud tone generated just from the bazooka tube, and not from the speakers, it does not have to do with anything from the engine's rpms. note that it does this also when the car is off. what i really wanna know is if my rca cables setup is correct.
Old Feb 24, 2003 | 03:59 PM
mcss383's Avatar
Is it the same sound as when you try to plug in a RCA to something when it running?
Could be a loose connection with the RCA's
When you moved them you prob fit them snuggly and they could have over time gotten 'loose'. I've never had any RCA's do that, but that could be the case.
Also check and make sure there aren't any cuts on the RCA's. If the RCA's are good then I would prob say get the amp/sub checked. The amp I had for my home theater sub went south and as soon as it powered up it just hummed.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
