blowing instrument lamp fuse since stereo install
i keep on blowing my dash lights ever since i installed my head unit...i made a wiring harness from the gm one...i have a jvc headunit....i installed it a while ago..im now getting around to fixing it...but...when i turn the lights on i hear a pop and thats the fuse...
whats making it do this?...yes i installed the headunit correctly...its just keeps blowing out the dash lights...
PLEASE HELP!!!
Thanks!
PLEASE HELP!!!
Thanks!
Car: 1983 "SS" Camaro, 2000 Mustang GT
Engine: .30 350
you want to double check your wireharness and make sure that the illumination (orange wire on the stereo harness, or the orange with white dimmer wire) are not hooked up. Sometimes this will cause an overload of the stock circuit and will blow the fuse. Does it do anything else other than blow a fuse for the dash lights? For example, blow the horn fuse or dome light fuse? Does it power on and off with the parking lights?
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Run a power line from the battery.
It may be drawing to much power, and blowing the fuse.....
Car: 1987 Camaro Z28
Check to see if your wiring harness is properly connected. If it is just the dash lights, I would suspect that the dimmer wire is either wired to the wrong connector or grounded out.
Car: '84 Trans Am
Engine: 305 H.O. Edelbrock 600cfm, XE262, ported L69 heads, Hooker cat-back
Is the brown wire not a ground? Why wouldn't you want to ground to it if it is a ground?
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Aug 11, 2015 10:11 PM
