Amp and antenna wired together?
Old Feb 25, 2003 | 01:49 AM
Enkil's Avatar
I was wondering if it was okay to run both the power antenna switch and the amp switch off the antenna line coming from the back of the headunit. I don't imagine it would be a problem, but I just want to make sure.
Old Feb 25, 2003 | 08:01 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Unless your deck has a separate lead for each, that's what you have to do. If you plan to add any other equipment that requires the remote turn-on (such as another amp or a processor), you'd be best off using a relay so that you don't exceed the maximum current draw of the deck's remote lead.
Old Feb 25, 2003 | 02:11 PM
Enkil's Avatar
*nods*.. It's a really really cheap headunit, I'm surprised it has a remote lead at all. I've currently got a switch on a line running off the battery, but it's a pain to keep switching them on and off.
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZsTransAm
Aug 11, 2015 07:30 PM
