where can I store an amp
Old Mar 7, 2003 | 12:39 AM
bam's Avatar
bam
I have a 89 iroc with t-tops. I have a box built for the trunk, and my t-tops lay over it. So where could I put a 600 watt amp.
Old Mar 7, 2003 | 12:51 AM
MdFormula350's Avatar
if your not running a spare tire then you could put the amp in their maybe..
Old Mar 7, 2003 | 12:53 AM
bam's Avatar
bam
I still wanted to keep my spare tire, just in case.
Old Mar 7, 2003 | 02:46 AM
how about on the other side in the storage comparment area somehow...
Old Mar 7, 2003 | 08:46 AM
92camaro44's Avatar
Just do what I did....drill four holles and mount it upside down from the box...ill have pics by the beginning of next week...
Old Mar 7, 2003 | 08:49 AM
transam305's Avatar
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
if you mount it on the underside of the box does it get enough air to it, to cool it off or does it overheat?? i'd try and put it in that little compartment off to the side it should fit if not make it fit lol...
Old Mar 7, 2003 | 10:03 AM
White Ninja's Avatar
do you use the storage box on the driver's side? i think that cardboard comes out and makes more space...maybe in there?
- Andy
Old Mar 7, 2003 | 11:22 AM
bam's Avatar
bam
all see if I can put it in the storage area. The amp I had before was a a little one and it fit there.
Old Mar 7, 2003 | 11:50 AM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
this is my experience, but be careful about putting it in those side compartments, there tends to be some moisture buildup in there and amps and water are not good bed partners. good luck
Old Mar 8, 2003 | 12:01 AM
DeathDealer's Avatar
Car: 1992 RS Camaro
Engine: 5.0 L03 TBI 305
Amp storage? This gets asked alot, but here are some ideas:
1. under the box (just beware of overheating).
2. In the spare tire compartment.
3. In the driver side compartment (White Ninja is right, the cheap cardboard comes right out).
4. Just in the trunk right behind the back seats (just don't screw it down!!!! Your gas tank is 3/4s of an inch down!! The best think is to use velcro).
5. Do what I want to do! Check out the tech articles and build it into the backseats themselves. Takes a little money and alot of time but if you want to show it off, its well worth it).
Just a few Ideas,
DD
92 RS
Old Mar 8, 2003 | 12:18 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
yeah, i'm doing the backseat thing too. just gotta get myself in gear and finish it
Old Mar 9, 2003 | 12:53 AM
KsKid's Avatar
anyone ever thought about mounting it to the very back of the car? on the inside wall underneath the hatch latch and all of that good stuff? if you have a box in there you could cut the pannel *cringe* but there does seem to be alot of room behind it. i'm asking because right now mine is out because my box doesnt fit so well with it in and i was thinking about doing it. the only bad side i can see of it is it might not get air (just like being mounted under the box) and if you ever got rear ended severly enough your kinda screwed. but with a box there your screwed anyway... atleast it could be hidden
Old Mar 11, 2003 | 08:53 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
There isnt enough room behind that panel to mount an amp. I have taken it off many times to mess w/ my trunk motor, and there is no way an amp is fitting back there w/o cutting a hole in the paneling so it can stick out. there are 3 ways I would recommend....they are listed from cheapest to most expensive.
1) mount it to the top of the box...like so
2)velcro it to to the hump on the back...dont screw it, just velcro it
3) put it in your back seat, this looks extremely neat and and professional!
Whichever you choose, good luck!
Old Mar 11, 2003 | 09:19 PM
92camaro44's Avatar
update...just mounted the amp upside down on the box, superglued and placed brackets on a sweet 12v fan which is between the amp mounted upside down and the other amp mounted on the bottom...works sweet...and its stealth
Old Mar 11, 2003 | 09:21 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
Pics man, post some pics! Sounds pretty cool.
Old Mar 12, 2003 | 08:25 AM
transam305's Avatar
yes.... do post pics i wanna see this sounds cool...
Old Mar 12, 2003 | 11:04 AM
92camaro44's Avatar
ive taken about 20 pics of the whole setup..i need to wait to finish the system(my cd player comes in the 12th or 13th) that day i will do one hour photo and make a cd...i will for sure post the pics..it took some creativity, but awesome job..recommend it to anyone
Old Mar 12, 2003 | 02:03 PM
transam305's Avatar
post em post em!:lala:
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
