Good place for a ground
Old Mar 11, 2003 | 04:47 PM
nhamze's Avatar
I was having trouble getting a good ground for my amp, where is the best place to hook up the ground wire on an 1985 firebird, a really need to know.
Old Mar 11, 2003 | 05:25 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
drill a hole, put in a screw, the whole body is a ground, it's not rocket science
Old Mar 11, 2003 | 05:35 PM
DeathDealer's Avatar
Car: 1992 RS Camaro
Engine: 5.0 L03 TBI 305
Gee.., be nice OntoGenesis. Its easy but some concern should be taken when grounding. I'm going to assume that your amp is in the trunk, so what ever you do, don't drill into the gas tank!! Thats one big no-no. The best place I found is the metal divider between the back storage compartment and the spare tire bay. Theres a short metal wall that works perfectly fine and is usally in range of the 3 ft. cable they give you with most amps. Hope this helps out.
DD
92' RS
Old Mar 11, 2003 | 08:10 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
In my opinion the best place to put it is on the bracket where the t-top storage thing is supposed to clamp on in the back, theres 2. Just sand down the paint and screw the bolt back on , works great!:lala:
Old Mar 12, 2003 | 02:37 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Another good place is where the rear seatbelt bolts to the frame of the car.
Infested
May 22, 2018 11:56 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
