Alt box, comments ? suggestions ?
Old Apr 10, 2003 | 02:24 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Ok, my current setup, is
Alpine CDA7893 Cd player
Memphis Audio "memphis belle" amp 75 x 4 + 1000x1
Boston Pro 6.5" component set in kicks
Boston Pro 10.5 sub in REZN8R stealthbox.
It doesnt seem to hit the low frequencies right, but im thinking i may just need to get it sealed a little better, and possibly try some poly fill.
But onto the main topic, i've been toying with the idea of having a 2nd box for when i really feel like having the boom in and heres what im considering, all will be a sealed box, lets hear some opinions.
1. 2 Eclipse Aluminum Cone 10's
2. 1 JL 10W7 RMS ?
3. 2 JL 10W6v2's
4. 3 Image Dynamic IDQ10's
Old Apr 10, 2003 | 07:52 PM
68Beater's Avatar
I would take those 2 JL's or Eclipses over the 1 JL or 3 10's...
That would be more than enough bass to get your feet tingling..
3 10's would be overkill, unless your really into SPL...IMO
Old Apr 10, 2003 | 11:01 PM
Xplicitblitzboi's Avatar
They are all pretty good choices, i would go with the w7 if you could, but you've got to have a box built like a tank. i have 3 10s, and its not overkill, it all depends on the amp. what amp are you planning to run this with? i have suggestions if you need them, but if you are planning on running any of these subs at their reccomended power you might want to consider a new alternator, and no, a cap wont fix the lack of power problem.
Old Apr 11, 2003 | 01:20 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Nah its a box problem, I played around with it last night and tried it in a friends car after adding some poly fill and making sure it was sealed up like tupperware. Still just not right on some of the lower notes. Then i realized the sub requiring a .5 cu ft box, and the box being exactly .5 cuft doesnt leave much room for the volume the huge backside of my sub is taking up. So im going to get a pair of IDQ 10's and fabricate some sort of box for the other side since they call for a .30 - .60 cu ft box and hopefully will prove quite well.
See original post for the amp.
Old Apr 12, 2003 | 05:28 PM
amp
well, if the amp is rated at 1000 watts RMS then that should run the w7 pretty well, but again, you have to have a pretty good charging system ie(stiffening capacitator, optima yellow top battery, High Output alternator) to be able to have a good system, and a new alternator is a must if you are going to be running the w7)
64goatman
Sep 9, 2015 01:09 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Jk_Under
Sep 8, 2015 08:13 AM
Slush92RS
Sep 2, 2015 08:56 PM
