My Box
Old Apr 25, 2003 | 03:36 PM
txhotRS's Avatar
My Box
Ok, someone who builds boxes... how much cubic air-space do I need for a 12" how 'bout for 10's... If the box has air ports ... DO I NEED to go by cubic feet, do you recomend sealing it (or only if you go by air-space)
Old Apr 25, 2003 | 03:58 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I don't build boxes; but chances are the manufacturer of the subwoofer has recommended a size for the enclosure... what's the make/model of the subs?
Old Apr 25, 2003 | 04:06 PM
txhotRS's Avatar
not real sure... Kenwood ... but I don't know the model... THANKS
Old Apr 25, 2003 | 04:08 PM
jawzforlife1's Avatar
If you look at the bottom of the magnet, there should be a model #, than if they are new enough, you can go to crutchfield.com and look them up. It will tell you how much cublic inches you need there.
Old Apr 27, 2003 | 10:57 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
The airspace inside the box is even more important with a ported enclosure than a sealed one. In general 10s require between .5-1.0 minimum for a sealed enclosure. Ported around .75-1.5. But you will need the manufacturer's specs first, because each sub is different. Some require a larger enclosure, and some are designed to work in really small ones. A lot of times you can go to the mfgr's website and they will list the info for several years of past models as well.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
