how will i get my JBL BP600.1 to power 2 subs
Old May 8, 2003 | 06:57 PM
stone89ROC's Avatar
Car: for now my Jeep while im building my Camaro
Engine: building a 350 with about 440HP and 450lb
Transmission: W.C. T-5 dont know how it will hold up..
im thinkin about gettin 2 alpine 12" type r subs and a JBL BP600.1 but how will i get it to power both subs it only says 600x1 or 300x1 at 2 ohm and my 12's are both 2 ohm
Old May 8, 2003 | 07:16 PM
White Ninja's Avatar
i take it they're dual 4ohms, wired in parallel to give you 2. Wire them both in parallel and then right into the amp, giving you a final load of 1ohm. 600w @ 1ohm.
- Andy
Old May 8, 2003 | 09:29 PM
stone89ROC's Avatar
well each 12 is a dual voice coil 2ohm heres the part number swr-1221d
Old May 11, 2003 | 11:16 AM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
If each sub is dual 2 ohm, then wire each sub up in series which gives you a 4 ohm load on each sub, the wire the subs up in parallel, which will give you a total of a 2 ohm load. The JBL is supposed to put out max power at 1 and 2 ohms. Good luck.
Wylecoyote08
Oct 1, 2015 09:18 AM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Slush92RS
Sep 2, 2015 08:56 PM
sailtexas186548
Aug 24, 2015 10:11 PM
