Sony CDX-5000X
Old Jun 6, 2003 | 01:21 AM
stiers's Avatar
Sony CDX-5000X
I am trying to install an amp and subwoofers for this reciever into my friends Camaro and I can't seem to get it to work. The reciever has 2 sets of RCA out, front and rear but whenever I plug the RCAs into it you loose the sound from the corresponding factory speakers on the recievers internal amplifier. So how in the hell are you suposed to wire subs up to the Sony Recievers? I also can't find an installation manual for this model anywhere so if someone has that it would be helpful....any ideas?
Old Jun 6, 2003 | 07:36 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
That an’t right. Have you tried a new set of RCAs or even running them to a different amp? I have the service manual for the CDX-5000x in front of me and I don’t see any thing else that could explain that. But if the RCAs where shorted or there was a short in the amp at the input that could cause this, but still vary weird and not at all likely. And you have the same results from the front and rear pre-amp outputs?
Old Jun 6, 2003 | 03:18 PM
stiers's Avatar
So it is not supposed to work like that huh...I tried a diffrent source with diffrent cables and the amp worked fine, so tonight I will probably try new cables.
Old Jun 6, 2003 | 10:01 PM
stiers's Avatar
Yea, same results from the front and rear preouts. The amp was pulled out of my car and worked fine with my Alpine deck and I also tested it with an MP3 player and it works fine. The problem is eitehr the cable or the reciever.
Old Jun 8, 2003 | 11:05 PM
stiers's Avatar
it was a bad set or RCA cables, not sure what the deal was but I tried a diffrent set and it worked fine!
Old Jun 9, 2003 | 02:31 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Good to hear.....
jrdturbo
Mar 31, 2016 02:58 PM
69 Six Pack
Oct 5, 2015 07:51 PM
mustangman65_79
Car Audio
Sep 30, 2015 09:37 PM
Josh 91RS
Car Audio
18
Nov 30, 2000 03:14 PM
