suggestion on setup
Old Jun 20, 2003 | 12:24 AM
jcjohnston78's Avatar
suggestion on setup
my current setup is a setup 4x6 inf. kappas and kennwood 6x9 4way rated at 220 peak watts. planning to go with inf. kapps 3way 6x9s
would u guys think its a good to put them on an amp. if so would it be better to run 2 seperate 2ways. also whats the best amp(s) for the job and what power rating.
eventually im planning to go with a stealth setup for the tube dont want to do that till i finish the interior and engine mods.
Old Jun 20, 2003 | 01:44 AM
onebadwagon's Avatar
get a good 50- ish watt rms 4 channel, that will power you for a long time. rockford/jl/pheonix/orion/etc.
i would recommend against using two separate amps on a basic system, because normally when you buy the 4 channel version of an amp, you get things like a built in high pass/low pass, subsonic filter, etc. whereas on the 2 channel, you could possibly only get the adjustble high pass.
adam
Old Jun 24, 2003 | 06:09 PM
prple hze's Avatar
Alpine makes a great 4-channel amp that is for people on a budget. It puts out 50 x 4 and very small in size. It can be installed under a seat also. I have installed a few of these and am suprisingly satisfied with its performance. I think th model number is MRP-F240 or something like that. It's only about a month old
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
R13_Braz
Sep 18, 2015 05:00 PM
64goatman
Sep 9, 2015 01:09 PM
Ranbo108
Sep 9, 2015 12:20 PM
Jk_Under
Sep 8, 2015 08:13 AM
