Variable ohm wiring on a single amp possible????
Old Sep 14, 2003 | 05:17 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
I have an Alpine MRV-F450 5/4/3 channel power amplifier. The power listings are in 4 ohm (50x4 RMS plus 200W RMS for the sub). My problem is that I noticed I paid for an Alpine Type R 10" sub and the store gave me an Alpine Type E. I just returned the wrong sub for the right sub and noticed the wiring to the sub is way different.
The type E was simple and you ended up with 4 ohm's if you wired it like a normal speaker. The Type R is a dual 4 Ohm voice coil speaker. It can be wired for 8 Ohm's or 2 Ohm's. Will it hurt my amp if I run my front and rear speakers wired as 4 Ohm and my sub wired as 2 Ohm?????
Old Sep 15, 2003 | 08:56 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
That amp will be fine at 2 ohms no problem.
Old Sep 15, 2003 | 09:47 AM
Captain C's Avatar
Car: 1985 IROC-Z
Thanks for the help!!!!! Didn't want to fry a brand new amp!!!!! I knew the amp was stable to 2 Ohms, I just wasn't sure if running 4 Ohm on channels 1-4 (front-rear speakers) and 2 Ohm on channel 5 (subwoofer channel) was going to be ok.
Old Sep 16, 2003 | 01:53 PM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
Those amps are really either two or three amp boards all in one casing. So, the front channels are pretty much separate from the sub channel, they just share a power source.
eightsixseven
Dec 16, 2024 01:50 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
ZsTransAm
Aug 11, 2015 07:30 PM
