Gargoyle Car Alarm ? !
Car: Camaro
i have a gargoyle car alarm installed on my car and its been disconnected and reconnected and wires moved around and so forth so basically its been through your regular typical... oh i like it there... no wait i want it there no over there... tuck that hide that i dont' wnat it i want it... that was all from my brother now i got the car and want the alarm hooked back up... it seemed to work fine at first... but then it started locking ... locking...... locking... like every 4 seconds... got it to stop doing that and now i push the button to arm it and it will arm and lock the doors... i push the button to un arm it un arms the car but sometimes it will unlock the doors othertimes it won't... . whats up with that ?? any suggestions...
Vetter
Vetter
Car: Camaro
Obviously you have no idea the complexity of car alarms. I'm not an expert here but I can tell you that it is alot of work to install one ecspecially for a begginer with out any expieriance. Why would I want to rip out a perfectly good alarm system just because of one little problem that only happens occasionally. Hell there is pry an easy fix to it, something that would take 5 minutes. Time to think logically now, the only reason I posted this was to get some help on how to diagnose the problem, not have someone tell me to rip it out and start over. If that were the case I would of just done that and not said a word. I work with what I have I can't afford to redo something as complex as that just cause one little part don't work. Helpful Feedback Welcome !
Vetter
Vetter
Just giving my opinion. It's easier to start from scratch than to try and figure out someone elses wiring job. If you don't like my advice there's no reason to get mad about it.
Car: Camaro
i am sorry for sounding angry and pissy towards you... any advice is better then NO advice right... you seem to be the only one giving out ideas so i best not be knockin you down on that... sorry for the attitude.... just the whole starting from scratch i have no idea how the wires run and where they all go and so forth it would just be a mess.... if anything i might just buy a new clip that goes into the alarm ecm box and rewire all the wires going into it to make sure they all have good connections and are not grounding off something or anything... thanks and i apologize for flamin towards you... keep it real man ... later
Vetter
Vetter
Linson
Aug 21, 2015 02:12 PM
