Using high level inputs on an AMP??
Old Nov 8, 2003 | 06:11 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
With a factory head unit, is it safe for the head unit's amp, to have the rear speaker outputs powering the speakers and running the same signal to high level inputs on an aftermarket amp? I know the Factory unit is not a high power one, so the other amp should be safe.. but would the Factory amp be ok with that amp wired into it also? Thanks
I did a search, and no one mentioned how safe it was to the factory amp system.
I know everyone says the late 80's early 90's factory decks are not good.. but I want it anyways.. ditchin my 2001 Clarion for it..
Old Nov 19, 2003 | 09:18 AM
87 GTA TPI's Avatar
Car: 1987 Pontiac Trans am GTA
Engine: 5.0L
Transmission: Dead 700r4
v.
Old Nov 19, 2003 | 09:43 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
will it work?
yes... ive done it before.
but the stereos that came in our cars have 2 main probs.
1. they arnt to great to begin with.
2. they get worse with age.
when i had my factory CD player installed, i wired everything up..... sounded like total ****... i couldnt believe how bad it sounded...
just to test, i put another old 3rdgen radio from a 87(i think) in there.... sounded terrible too..
then i connected a old alpine unit... and it sounded so clear....... so i re wired everything for the low level out puts...... then i find the alpine wont play CDRs....... so i get a cheap $120 pioneer...
sounds clear and plays CDs now..
looking back, i think the problem is that the really low freqs are distorted by the stock stereo... and when you amp that noise, it gets much worse.... you will notice it.
now some of the the later 4thgen models are great.... no distortion when you amp thoes
so if you want that stock GM look and want to just pick sound off the speakers, id swap to a 4thgen headunit, and run a high to low level converter box, into the amp. GENERALLY speaking, a good brand name converter is much "cleaner" then the built in on amp converter
Old Nov 19, 2003 | 09:58 AM
87 GTA TPI's Avatar
Engine: 5.0L
v
Old Nov 19, 2003 | 10:00 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Originally posted by 87 GTA TPI
Usually what happens is one of the outputs on the factory unit will go in and out. Then eventually they will all go some day. We will all go some day.
thats usually a loose connection..... if you can find what broke or what trace lifted off the board, you can usually fix that.
Old Nov 19, 2003 | 10:27 AM
87 GTA TPI's Avatar
Engine: 5.0L
v
Old Nov 19, 2003 | 10:41 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Exactlly my point, Why bother with fixing the factory? Its not worth it in the long run.
theres generally 3 reasons people like factory.
1. they want to keep it looking factory
2. theft prevention. a great point when you have a vert.
3. they're totally broke
theres also the fourth "i just dont care" segment, but they really arnt part of the conversation....
in anycase 5mins with a hot soldering iron is worth it to anyone in thoes 3 catagorys..... and if you screw up, you can try again with another one.
Hotrodboba400
Dec 10, 2019 07:07 PM
corey8084
Sep 17, 2015 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
