Speakers under dashpad?
What size are the speakers under the dashpad, i've never been under there. Where can I get speaker kick panels?
Anyone know someone who has 2000W in their hatch? I'm getting RF Power 12s and two RF 1050S amplifiers to power them, hope my hatch will survive. :lala:
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
read the car audio tech articles in the "tech" section of the website.
i would advise keeping the windows down if your going to run that much....that is if the equipment truly puts out that much.
i will be pushing upwards of 4 but that is not continuous so i'm not worried.
if your putting that much power and money into the setup you should know all the shortcuts already or your installer should take care of any possible problems you may come along.
good luck and post some pictures.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Your hatch should survive easy. I'm running 2 18" CVRs with a JBL 1200.1 amp on each. I don't have any hatch problems yet. Course the SPL is killer so if you're gonna listen to it loud need to crack a window a little bit.
your running two 18" speakers in the back of a thirdgen??? i didn't know they would be that low in power. the only speakers of that size i've ever seen were easily over 4,000 nominal which would be absolutely overkill for a thirdgen.
that's a bit much.
that's a bit much.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Originally posted by Kandied91z
that's a bit much.
that's a bit much.
what fun is this hobby without going overboard
Engine: 383 SBC
Kicker 18" CVRs are 1000 rms and 2000 peak
I don't want to be a thread highjacker so I'll just post a pic and you guys can come to the website and check out the car if you wanna see the rest of them.
http://www.sounddomain.com/memberpage/433125/
