yay!!!!
Old Dec 10, 2003 | 04:19 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
yay!!!!
just ordered my new subs and kicks about 5 min ago!!!! cant wiat to get them. even though i wont hear them until spring.
here is what i got:
2-12" Kicker Solo-Baric L5 Dual 2 Ohm
1-Set of Q-Form Kick Panels
Old Dec 10, 2003 | 04:29 PM
tyty49's Avatar
Car: 91 Maro & 97 Ram & 05 Roadstar
I can't wait to see them once they get installed. Can I ask where you order them from?
Old Dec 10, 2003 | 04:34 PM
92MaroRS's Avatar
ordered them from sounddomain.com
i will aslo be getting:
1-KX600.1 amp
1-KX800.4 amp
1-Resolution 6.1 or 5.1(depending on which will fit in the kicks)
1-resolution 6.1 for the sail panels.
if anyone knows of the best way to go about mounting the components in the sail panels let me know.
Old Dec 10, 2003 | 10:04 PM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
wouldn't you need 2 6.1s for the sails and kicks? 1 on the left and 1 on the right.
Old Dec 11, 2003 | 12:00 AM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
He probably means 1 pair, not just one speaker. I believe the Q-Forms take a 5 1/4" speaker.
Also, why do you have listed a KX600.1 and a KX800.1. Do you mean the KX800.4? Just so you know now, those amps are HUGE and are going to draw a lot of current. Make sure you have a more that adequate charging system. Good luck and take pics when the time comes around.
Old Dec 11, 2003 | 11:22 AM
92MaroRS's Avatar
yea i mean KX800.4 and i read on sound domain that the kicks will hold some 6.5 components so im wating to get them and then measuer how big i can cut and then see how big of a hole i have to cut for the 6.5. and yea i think they only come in pairs.
ive already got a Deep Cycle Battery for it(had from my old car) and the previous owner had a sound system and supposedly put a larger alt on it and the car is supposedly been dynomatted. and yea ill have plenty of pics of the install but that isnt happening until mid to late march even tho i will have everything by the end of january. and the install should look killer. im gonna get the grills for the subs and paint them to match my car along with the shrouds for the amps. i also plan on getting a 1.0 or 1.5 farrad cap to go with it. also it will get purple power wires to match my car. DAMN I CANT WAIT
RedLeader289
Sep 23, 2015 06:50 AM
MrDude_1
Jun 29, 2003 02:21 PM
MrDude_1
Jun 27, 2003 10:33 AM
C-Dawg
Apr 10, 2003 12:27 AM
dunerida82
Jan 8, 2003 08:58 AM
