cap question
Old Jan 14, 2004 | 02:55 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
cap question
i knwo alot of you dont like caps but i had one in my old car and it made a huge difference so i am going to be putting one int he camaro. yes i will be upgrading the wiring and charging system also. and i know that its 1 farad for every 1000 watts but my question is should i put the cap before the distro or get two and put them after the distro? the system will consist of a KX800.4 amp and a KX 1200.1 or 600.1
Old Jan 14, 2004 | 03:22 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Well, I'd either get a big mo cap before the distro like a 1.5f or 2f, OR have like a 1f after for the killer big amp (I posted in the other thread, we have matching amps ), then a 0.5f or 0.75f for the smaller amp.
Now that I think about it, I'm thinking you may want a cap for each amp - I think that's going to give you the best performance results.
Old Jan 14, 2004 | 03:41 PM
onebadwagon's Avatar
you want the cap as close to the amp as possible.
adam
Old Jan 14, 2004 | 06:50 PM
learsieglerZ'83's Avatar
Car: 1983 Z28
Transmission: 5 speed
unless youve got some mad amp sucking amplifiers then there is no need at all to get two amps. i have yet to see many installs in 3rd gens that would need 2 caps....and unless you have a really bad amp for your front speakers there should be no reason at all to use a cap with it. im running two amps right now and i have no problems at all with drawing to many amps from my battery/alternator. regardless ive only got about 550 watts, but it sounds like you may have a bit more than that
Old Jan 14, 2004 | 09:28 PM
92MaroRS's Avatar
well i kinda figured i wouldnt need two caps but i do have two amps. and i was just wonderin if it would be a better idea to have the cap before or after the distro. i was thinking along the lines of 1-1.5 farad
Old Jan 15, 2004 | 01:54 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Place the cap as close the the amp as possible. The longer the wire, the less effective the cap will be, and dont place a fuse between the cap and amp. There are special cap connectors that act as a dist block so you can hook it up to multiple amps, just make sure to use short cap-to-amp power wires. Less the 6" would be ideal.
Old Jan 15, 2004 | 03:40 AM
92MaroRS's Avatar
anyone know of a cap with a distro on it that takes 0 gauge and splits it into two 2 gauge lines or a 2gauge line and a 0 gauge line.
1992 Trans Am
May 10, 2023 07:19 PM
chazman
Aug 28, 2018 03:25 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
