quick questions about box volume
Old Jan 13, 2004 | 07:54 PM
rscamaro305's Avatar
Is the amount of space needed with the speaker in the box or with out it? meaning do you calculate the volume of the come and subtract it from box volume. Second if you run 2 subs do you have to divide the box and give them seperate volumes or can they share volume. for example, can you put two 1 cubic foot subs in a 2 cubic foot box? does any of this make sense? thanks for any help. rock on
Old Jan 13, 2004 | 09:16 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
Re: quick questions about box volume
box specs usually call for the actual air space in the box that can be used. So you take out the displacement of the sub, dividers, and ports.
usually it is a good idea to divide a box if you can because if one sub blows then the other sub will have twice the box space and the same power which could damage it. With a divider if one blows the other will play fine.
Old Jan 14, 2004 | 12:26 AM
thanks a lot for the help, you rock
Old Jan 14, 2004 | 03:17 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
are you building a sealed or ported box?
Old Jan 15, 2004 | 09:43 AM
sealed. does it matter? and if it does matter why?
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
BBSDesigns
Aug 11, 2015 07:39 PM
