I Need help choosing speakers!
Old Feb 3, 2004 | 03:04 PM
KC10Chief's Avatar
I have an 88 GTA. Last spring, I bought a Kenwood head unit with a satellite radio setup. I like it so much, that I'm going to put it in my wife's car and upgrade my head unit. I also have the factory 4x6 speakers up front, and some Sony Xplod 6x9's in the sail panels. I also have an Infinity Basslink 10" sub mounted in the spare tire compartment. Sounds pretty good, but I wanted to upgrade the front speakers and the 6x9's. I've been reading on here a lot and read that 6x9's aren't that great. Does this matter since I already have a sub? Should I get 6.5" speakers for the back? I already figured I'd get 4" speakers up front. Another thing I was looking at was the Q-Logic kickpanels so I could mount front speakers there. If I did do that, would I no longer use speakers in the dash? Would you guys recommend that in the first place? I've been looking at Kenwood, Rockford Fosgate, and Infinity speakers. What do you guys recommend I do? I like to listen to my radio loud, but I don't need it to be heard a block away. I like the bass kind of punchy. I probably have my basslink adjusted a bit wrong. Don't know much about it. MY 6x9's get kind of distorted at high volume. I have to turn it down lower than I would like to keep the speakers from distorting. Thanks for any info! Matt
Old Feb 4, 2004 | 10:18 AM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
If you're running your 6x9 off of the radio with no amp, ANY speaker will distort because you don't have enough power. You're driving the radio into "clipping" (distortion).You need an amp. I would recommend an Infinity speaker.
Old Feb 4, 2004 | 11:01 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The kenwood has enough power to play reasonably loud before it distorts. If you want more bass than what you're getting now, you can add a sub and an amp for that sub, and keep powering your 6x9s off the head unit. Most kenwood head units allow you to run the speakers in a high-pass configuration. In other words, the kenwood has a crossover to filter the bass out of the speakers that it is powering. This is a VERY useful tool, especially for the specific configuration that I just mentioned.
When you run this sort of configuration, it'll get a lot louder than you think. The 15 or so watts that the head unit is capable of producing goes a long way when you filter the bass out of it.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
bjpotter
Oct 4, 2015 07:48 PM
Vincent135
Sep 28, 2015 10:50 PM
