Speakers
Old Feb 4, 2004 | 03:10 PM
89rallylicious's Avatar
Car: 91 z28 (RS Trim) Ttops
Engine: 5.7 350 roller crate
Speakers
revamping another 89 RS and tryin to decide what to do about speakers.. have two 6x9's in the rear, one in each kicker panel, but dont know what would be the best up front. cut into the door? i was hesitant to do that, maybe the dash? i think the dash has been recovered, i thought there were origionally little ones there. suggestions
Old Feb 4, 2004 | 06:07 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Speakers
There are two 4x6 speakers in your dash. No real need to relocate them unless you added kicker panels to jazz up your interior and sound sytem. Check out over on the audio board for more detail. I only have 4 speakers and 2 subs and it rocks.
Old Feb 4, 2004 | 06:24 PM
cdoyle's Avatar
custom kickpods are the way to go, they will improve your front stage dramatically.
I have them in mine, and can't believe the difference they made. I have a 5 1/4 and a tweet. You might be able to build one that can house a 6.5, but not sure if space would become an issue.
you'll never get a good sound out of a 4x6, and with such a small speaker up front, and 6x9's in the back your soundstage would always sound like its behind you.
Chris.
Old Feb 4, 2004 | 06:25 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Moving...
Old Feb 4, 2004 | 06:49 PM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
I did find the 4x6's on the front were 10 ohm speakers. They seem to handel a bit more low end than most aftermarket speakers.
However, I surely agree that components in the front would be the best.
I have often thought of either components in the back sail panel areas or at least some good coaxial speakers. Just make some adaptor plates for them from MDF.
Old Feb 4, 2004 | 09:41 PM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
Put some Subs in the trunk a cross over unit in for the 6x9's and the front 4x6's to remove a little bass from the 6x9's and all the bass from the 4x6's. Then the front speakers can go as loud as you want without distorting and if your still not getting enough highs you can add some pillar mount tweeters.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
codeysabatini
Sep 20, 2015 11:36 AM
