Amp is goin crazy
Old Feb 23, 2004 | 07:49 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Amp is goin crazy
My kenwood amp when ever i turn on my stereo it makes an awful popping sound and whining which it never did before i know the problem is with the RCA ports on the amp. My question is where can i find replacement parts for my amp. I opend it up and got the part numbers off the broken board.
After i put it back togheter i thgoht it might work but it didnt and now my EQ wont turn on so i think it blew the inline fuse to the EQ. How ever my headunit still works even tho i have no sound. Any i deas on this one?
Old Feb 24, 2004 | 07:50 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Re: Amp is goin crazy
Originally posted by FAST RS
...I opend it up and got the part numbers off the broken board.
Well first there are no part numbers on the board, only location numbers. Without the service manual those number will not help you much. You said broken board, is it cracked? Second, how do you know what parts are bad? The only thing that goes wrong with most RCA inputs is that if the amp gets smacked hard at the RCAs it will brake off the leads. With the EQ, is this one of these “booster EQs”? Check it for B+, Rem, and ground. Did you have a good ground to the amp? Did you disconnect the ground with the RCAs plugged in.
Old Feb 24, 2004 | 11:23 AM
FAST RS's Avatar
ITs the RCA connectors that are bad i took a corner hard and the amp went with it and im pretty sure it messed up the rca jacks when ever i would plug the rca jacks into the A side no matter what it would go crazy and start popping when i would plug it into the B side it would work fine until i hit a bumpy road or it just wanted to act up. I think i might brake down and buy a new amp.
The borad it self is in perfect condition only bad thing is the rca jacks on it. When i took it apart everythign seemd like it was in good working order i didnt see anything wrong but i know its the rca jacks,
Old Feb 24, 2004 | 11:25 AM
FAST RS's Avatar
it is nopt one of the booster EQ's
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
raymondandretti
Sep 27, 2015 06:43 PM
