Lightning Audio S2.500.4 AMP
Old Feb 27, 2004 | 05:20 AM
Bebefouch's Avatar
Heres the specs on this 4 channel amp...
4ohm load
40w x 2 FRONT
100w x 2 REAR
2ohm load
80w x 2 FRONT
200w x 2 REAR
4ohm load bridged (mono)
160w x 1 FRONT
400w x 1 REAR
I have a very hard time understanding this stuff because i'm new to car audio. Anyways, I have 2 decent 4 ohm 6x9's that can handle a lot of juice (100w rms). I want to power them to their full potential, but I don't want to bridge them because I want the stereo sound. I have two 12" single 4 ohm voice coil subs that I would LIKE to bridge.
Given those specs, and the way I want to wire my system, how much power exactly are the 6x9's going to get, and how much power are the subs going to get??
Old Feb 27, 2004 | 02:56 PM
Bebefouch's Avatar
TTT
Old Feb 28, 2004 | 09:53 AM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
Re: Lightning Audio S2.500.4 AMP
4ohm load
40w x 2 FRONT
100w x 2 REAR
2ohm load
80w x 2 FRONT
200w x 2 REAR
160w x 1 FRONT
400w x 1 REAR
your 6x9s i assume will be on the front channels, so they will get 40watts each.
if u wire ur subs in series so its 8 ohm it will get 200 watt if u wire them to 2 ohm parralell then u should have ova 400 watts but i dont think those amps r stabl;e at unda 4 ohm
or u can run it unbridged. and get the 200 per sub which i think is your best bet, for sound qaulity and longevity
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
