Ill Effects of incorrect gauge wire
Old Mar 18, 2004 | 08:34 AM
Scotty562's Avatar
Car: 2001 SS Camaro
Axle/Gears: I should know this
Other than a the obvious fire hazard. Is there any performance loss.
For example, using an 8 gauge wire, where the proper wire is a 4 gauge.
Old Mar 18, 2004 | 09:08 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
it'll become a bottleneck for current in that it cannot supply the needed amount through the small sized wire...but yeah Fire is a big one too worry about, do you really need more reason
Old Mar 18, 2004 | 09:24 AM
Scotty562's Avatar
Car: 2001 SS Camaro
just curious, haha
Old Mar 18, 2004 | 10:43 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
To small a power wire WILL cause the power supply in your amp to die pre-maturely.
Old Mar 18, 2004 | 09:28 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Is it possible to use a guage that would be too large? Say the aplication calls for 8guage wire and you drop in 4 guage. will this cause an issue?
Old Mar 19, 2004 | 01:49 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
nope other than your amps power and ground terminals might not accept that big of wire
Old Mar 19, 2004 | 09:28 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
in general I would use 4 at least my friend is gonna be using 0/1 gage wire. it all depends on how much your drawing.
Nate
Old Mar 19, 2004 | 10:40 AM
Scotty562's Avatar
Car: 2001 SS Camaro
how much can 4gauge carry?
how much can 8 gauge carry?
I searched google, but all i got was junk.
Old Mar 19, 2004 | 04:54 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
it depends how long the wire is
http://www.eatel.net/~amptech/elecdisc/wire.htm
Old Mar 19, 2004 | 09:11 PM
ThraxXx's Avatar
Well I am gonna be running both 1000 watt amps in my T/A. I plan on putting 4guage wire from the bat back to my amps and then using a distribution block and using 8 guage wire to go from the distro box to my amps and then using 4 guage from the amps to the grounds...I think that will work. The wires won't be long between the amp and the block.
Old Mar 20, 2004 | 05:23 AM
Scotty562's Avatar
Car: 2001 SS Camaro
Wire Gauge Current Flow Max Total Amp Power
Class AB (60% eff) Max Total Amp Power
Class D (75% eff)
8 awg 52 amps "430 watts" 537 watts
Does that mean my amp will only be able to make 430 watts max if 8 gauge power wire is run to it?
4 awg 131 amps "1084 watts" 1355 watts
If thats the case then i am starving my amp of power.
Old Mar 31, 2004 | 02:23 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
I would not run 2 1000 watt amps off of 4AWG, I would use at least 2AWG...
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
