dual alternator setup
Old Mar 24, 2004 | 08:28 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Is anyone running one yet, I have a setup in mind that might need it..
Old Mar 24, 2004 | 11:01 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
i had 4 stock alts in my first car...at $25 each it was the most economical option
for 90% of setups out there one larger alt will do the job and cause less problems
Old Mar 25, 2004 | 08:25 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
You would probably be better off with one BIG alt..
Old Apr 5, 2004 | 05:47 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
...and a nice sized cap never hurt either
Old Apr 5, 2004 | 05:55 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
hurt the wallet
Old Apr 5, 2004 | 06:11 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Originally posted by Boomin Boy
hurt the wallet
That it will.
But your better of with a higher compacity amp in the long run, it will produce more power, all the cap will do is keep a small reserve for the amp, it really does nothing.
Old Apr 5, 2004 | 06:56 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Also heres more involved with running two alts in your car then just figuring out how to mount it and run the belt. Like everyone else said buy a HO alt. They have sizes so high in output that you'll never have a problem.
BTW DONT waiste your money on a caP.
____________________________________________________
KJ SAID:::::But your better of with a higher compacity amp in the long run, it will produce more power, all the cap will do is keep a small reserve for the amp, it really does nothing.
__________________
Still trying to figure out what you ment KJ. Did you mean alt?
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
R13_Braz
Sep 18, 2015 05:00 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
