Question to everyone not just boomin boy
Car: 92 Camaro RS
Engine: 3.1 L
Ok im sorry i caused such a problem before it was my intent at all. Someone told me when i asked a previous question they said "Put boomin boys name in your subject he shoudl beabel to answer it" so i did I didnt realize it would cause a problem so im sorry for doing that. And also i know i dont know anything about this type of things, thank you for reminding me
Ok so the real problem here. Ok im sure most of you read the other post and know whats going on im retarded and cant get this thing together. I have a bazooka EL1500 its 500W 1-channel. Im guessing that means only 1 spot to hook up speakers. And i have 2 12" EL 1204 they are 4 ohm. I have them hooked up +from amp to + 1st speaker then from +of 1st speaker to - of 2nd speaker and opposit for the other speaker. Is this wrong, from what i read i believe it is. And also there is no wire hanging off my head unit to put my REM cord into so i was wondering if anyone could let me know how to fix that up. Thankyou
Mitchell
Mitchell
I don't think it was you that caused a problem, but kids posting unless info and trying to cause problems.
It sounds like you have them hooked in series right now. If your amp is 2 ohm stable, you should hook up the positive of both subs to the positive on the amp, then hook the negatives of both subs to the negative of the amp to make a parallel circuit.
HTH!!
HTH!!
Car: 92 Camaro RS
Engine: 3.1 L
Ok how do i know if they are 2 ohm compatiable all i know is they say 4 ohm on the back. Sorry to sound so stupid but tahts all i know?
I just red up on my speakers and it says they can handld 4 or 8 ohms? whats that meant
Car: 92 Camaro RS
Engine: 3.1 L
Yea i checked it out it says it can handle either 4 or 8 ohms, im not sure what that means but how should i hook up my speakers from 1 speaker output from the amp thanks
Mitchell
Mitchell
Car: 83 z28
Engine: 300hp 355
that amp is 2 ohm stable so to run a 2 ohm load with (2) 4 ohm subs you will want to wire them in parallel. In other words, connect the positives from both speakers to the positive on the amp, an then both speaker negatives to the negative on the amp.
Car: 92 Camaro RS
Engine: 3.1 L
how do you know that my amp can handle 2 ohm? are you sure it does, and also can my amp handle 2 4 ohm speakers???
Also where do i hook up my rem wire if i dont have a wire hanging off my head unit they all go inot the black hose?
Mitchell
Mitchell
Car: 92 Camaro RS
Engine: 3.1 L
I have no antena at all, i guess when my bro wrecked it in 97 the antenna was lost in the carnage. So i have no idea, can i hook it up on the fuse box in the ign slot???
Mitchell
Mitchell
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Look on the back of your head unit at the wires coming out. Their should be a wire thats label says power ant etc. OR if you have a multimeter you can turn the headunit on and check the wires. It shouldnt be too hard to find. I have an old poineer head unit laying around and on this the remote turn on wire(power ant wire same thing) is blue with a white stripe.
Car: 92 Camaro RS
Engine: 3.1 L
I have 2 wires that are blue with a white stripe. One is dark blue and the other is light blue, both with a white stripe. Just wondering which one to use thanks Mitchell.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
More than likely it's the dark blue, but there's nothing wrong with trying them both.
I can promise that it's either one of those.
Car: 83 z28
Engine: 300hp 355
Mitchell
Mitchell
http://www.mobilcaraudio.com/catalog...7999/73645.htm
Car: 92 Camaro RS
Engine: 3.1 L
Thanks for looking that up boomin. Now with that type of amp and 2 4ohm speakers what kind of wire setup should i do the parallel one you guys were talking about. + from amp to + in both speakers and - from amp to - in both speakers
when im hooking up the wires are there going to be 4 wires coming from the amp sending 2 wires to each speaker?
thanks AJ ill just try both one of them has got to work.
thanks
Mitch
thanks
Mitch
Car: 85 firebird
http://www.infinitysystems.com/caraudio/3-4-2.aspx
here ya go man, almost any wire config you can think of
Car: 92 Camaro RS
Engine: 3.1 L
Thats an awsome website but what setup am I looking for? I have no idea what that stuff means its like reading german (which i took 2 years of and passed my 1%) so im not very good at it.
Thanks Mitch
Thanks Mitch
Car: 85 firebird
http://www.infinitysystems.com/caraudio/2-4-2.aspx this one dude
Car: Trans Am GTA
Transmission: Rebuilt 700r4 with stage 3
Relax 6cyl, there are plenty of us who do this everyday!
Some people are a keg of information waiting to be tapped..
some people just feel bad for others
We all started somewhere
Woo hoo 100
Woo hoo 100
