6x9 vs 6.5" speakers
Old Apr 11, 2004 | 11:06 AM
white91formula's Avatar
Car: 91 formula
Transmission: t5
ok i did a search but i coudl not get a straight answer from anythign i found.
i have just put some new 6x9 pioneers in the back of my car and tehy do no sound good, and after 3 layers of brown bread i will have alot of rattles.
would i get better response from making a plate and sticking some 6.5" speakers in the sails ?
what are the pro's and cons of each speaker being in teh sails ?
p.s. btoh sets would be run off a kenwood amp.
Old Apr 11, 2004 | 01:35 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
the rattles are probably coming from the plate the 6x9's are mountned in, It shakes and hits the body of the car causing rattles . You need to take the plate off and dynamat (or whatever) under it. Also you wont get the bass you think you would from this area because inside the sail panle their is a hole leading back to the back of the car. Seal this area tight with fiberglasss and bass would improve.
Also, components sound better than oval speakers overall.
Old Apr 11, 2004 | 02:17 PM
CrazyHawaiian's Avatar
Car: too many ...
When I do my system I'm gonna go with a 6.5" component set instead of the 6x9's. Just like br()bert said, components sound much better than packaged speakers (like 6x9's). I lost the link, but there is a company that makes the enclosure conversion plates for our 6x9 space to run 6.5" drivers. Then the only matter would be mounting the seperates for the rear speakers. I would also do what br()bert said, and make sure you 'band-aid' up the enclosure space with dynamat or other materials.
Old Apr 11, 2004 | 06:34 PM
9177's Avatar
Do they sound bad just becuase they rattle? If thats the case getting 6.5s won't help that. If the speakers sound bad regardless of the rattles and you are going to buy new speakers I would also recomend 6.5s. Iintead of using fiberglass to seal the spaces behind the speakers you can use expanding foam.
Are these running off of the HU power or off of an amp?
Old Apr 11, 2004 | 07:47 PM
Car: 91 formula
Transmission: t5
they are amp'd but even when they were on the hu they still rattled, they sound bad because of the rattles
if i was to eclose i would use fiberglass and not expanding foam, not going to go through that and have it wreck my quarters
Old Apr 11, 2004 | 09:49 PM
CaysE's Avatar
Personally, I would try to hunt down the rattles first. Like br()bert said, put down some dynamat before you mount the speakers. Also check the vents in the door jambs, as they rattle a lot too with aftermarket 6x9s.
I know I've seen plate setups in 6x9 form that come with a 6" driver and a tweeter pre-mounted. If I find one I'll post it.
Old Apr 12, 2004 | 05:53 AM
Car: 91 formula
Transmission: t5
i did dynamat, all inside the sails, wiht like 3 layers in most spots on all of hte insdie of the sails and on hte outside wall under the plastics
it is beyond me what is rattleing
Old Apr 12, 2004 | 03:19 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
My 6x9's rattle my door handles and the linkage in the doors... that really can't be fixed except maybe by some axle grease.
Also my door vent thing (in the 1/4 panel part) rattles. Sounds great if you take it off, but looks like a ss.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
codeysabatini
Sep 20, 2015 11:36 AM
