Subs with Neons, 12V power source
Old Apr 17, 2004 | 05:39 PM
drdroopy's Avatar
Car: 1991 Firebird
Engine: 3.1 V6
i bought a box with neons installed in them, requires a 12v power source, i was wondering where the best place to pull that from would be, any specific wires i would use and what not, cause last time i wired a neon the thing blew within a day, thanks for the help all
Old Apr 17, 2004 | 09:09 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
The same place that you get the power fro the amp
Old Apr 20, 2004 | 09:01 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
12 v power
you can use the same power source that triggers your amps but that isnt always best to have big neons on in your car all of the time especially if the law is a pain like it is here in houston. I had some at one time and had them wired to a independent toggle switch make sure you use an inline fuse as well for safety reasons. so that you can just trun them on when your cruisng the cool spots
Old Apr 21, 2004 | 01:13 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
you can hook them to the remote wire off of your deck/amp but personally i would hook it to its own toggle switch and mount it somewhere, there are times when you dont want your car to be the centre of attention
Old Apr 21, 2004 | 06:20 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
hook the ciggy lighter up to a wire and run it to the lights or run a custom switch.
Nate
Old Apr 21, 2004 | 07:41 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Re: 12 v power
Originally posted by robsgta
you can use the same power source that triggers your amps ...
If your not using a relay, doing it this way is a great way to kill the HU. Want to buy a new HU?
Old Apr 21, 2004 | 05:08 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
Re: Re: 12 v power
as long as you dont use a whole wack of neons you should be ok...they dont draw very much current at all. Ive done it in a few installs with no problems
Old Apr 21, 2004 | 07:01 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
the best bet is to run a relay. its just safer to do. most people recommend running a relay if you have more than 2 amps hooked up to the remote line, just because it sucks to have to replace a perfectly good headunit because you blew it on a neon. just be safe
Old Apr 22, 2004 | 07:47 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
MOST HUs are rated at LESS then 500mA on the remote line, some lower then that. As a rule, if you don’t know the rated output on the remote out line, keep it UNDER 250mA-300mA (some cheep amps will pull that on the rem. line). It all depends on the make/model of the HU and how they operate the remote outline.
I agree that you “should” be OK. The problem is a neon can pull a good chunk of current at startup. That “spike” is all it takes sometimes. I fix two or three HUs a week with this type of damage. Just depends on how they’re operating the remote line in whatever particular HU you’re using.
89GTAOz
May 16, 2020 09:31 AM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Jae992
Aug 27, 2015 09:07 AM
sailtexas186548
Aug 24, 2015 10:11 PM
