Harness Ungrounded?!!
Old Apr 23, 2004 | 12:20 AM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
OK i got my deck installed and whenever i move the harness the accessory fuse pops and im like wth?!.. i checked the wires in side the radio part and their fine... where else should i check if my radio harness is blowin fuses?! any help would be greatfully appreciated:hail: :hail: :hail: :hail:
Old Apr 23, 2004 | 01:35 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
a positive 12v wire is touching ground in there somehow.
There's really nothing much else that will cause that to happen.
Unravel all the tape and wire loom around that area and look for broken insulation on the wires. correct the problem with tape or rewire if necessary.
it is most likely touching chassis ground, and is right away visible, possibly on a corner or sharp edge...use a flashlight.
Old Apr 23, 2004 | 03:35 PM
7plagues's Avatar
Thanx ill try that out ill update with my results.
KO1
16
Oct 15, 2015 05:00 PM
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
z28joe2
Sep 28, 2015 05:54 PM
Eric-86sc
Sep 28, 2015 11:37 AM
