speaker wiring question
Old Apr 27, 2004 | 11:25 PM
92formula305tbi's Avatar
I am putting a new head unit in and c ant tell the difference between neg and pos when trying to hook up the speakers. no wires have a stripe. Will it affect the sound quality if they are backward?
Old Apr 28, 2004 | 01:25 AM
onebadwagon's Avatar
if all of them are backwards, you wont notice, if some of them are backwards, you still probably wont notice.
Old Apr 28, 2004 | 01:39 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Yeah that is if you are totally deaf.
Old Apr 28, 2004 | 01:43 AM
Old Apr 28, 2004 | 05:31 AM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
You know, With low quality stuff you probably wouldnt notice, But I found out after a few years involved with stereo stuff it really does make a difference. Try hooking up 2 subs off an amp with one hooked up backwards, It will kill your sound...Thats how I found out, I had a friend try to diagnose why my subs werent hitting and he explained it to me, That was 4 years ago!
Old Apr 28, 2004 | 10:49 AM
CaysE's Avatar
THE method for determing which way to hook up your speakers is as follows:
hook up the wires to your speakers as normal and mount them where they should go. You're going to have to look up the specs on the headunit in your manual to determine which wires are pos and neg COMING OFF THE HEADUNIT.
Next, get yourself a AAA or AA battery (9-volt will work too, but puts out more power than necessary). Take the two wires coming from one speaker, and connect them to each end of the battery. If the speaker pushes outward, then the positive wire is connected to the positive terminal on the battery, and you should connect that to the positive wire coming off of the headunit. Then attach the other wire to the negative wire off the HU.
If the speaker pulls inward, it is reversed. Attach the wire connected to the negative terminal on the battery to the positive wire coming off the HU. And of course, attach the other wire to the negative wire.
Repeat for all four speakers and you're done. This is the only way to be 100% sure as far as I'm concerned. It does require some splicing though, so be sure to have some tools and shrink tubing available. Electrical tape sucks.
Old Apr 28, 2004 | 07:56 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
if all of them are reversed, you wont notice a difference, since all of them are still in phase with each other. however, if one is and not the others, you should deffinately notice
Old Apr 28, 2004 | 08:16 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
You couldn't be more wrong!!!
enjoy your wretched 'cross polarized' music
argue if you want, but don't hate me because my ears still work.
Old May 2, 2004 | 11:34 AM
CaysE's Avatar
It doesn't matter if you won't notice the difference... you should wire them up correctly.
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
89lsc
Aug 14, 2015 04:58 PM
