bridging
Old May 1, 2004 | 04:00 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
bridging
when you want to bridge the subs, do you have to change the connections inside the box as well? Like on my box, the postive and negative leads are running off of the 2 connections on the box then correspond to the subs.
Old May 1, 2004 | 08:27 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
You didn't go into alot of detail here.....
but let's say the subs are already in paralell (one pair of terminals connecting two subs) this should be roughly 2 ohms when read with a meter......in that case no
lets say, you have a pair of terminals for each sub.....no again, all you need to do is connect the wires in paralell OUTSIDE the box. electrically it would be the same.
whatever you do, you should have the same impedence or above for your amp bridged.
Old May 2, 2004 | 04:17 PM
2 dope's Avatar
Engine: 305 LG4
i meant like, i don't have the subs installed in the box yet but the connections are already leading off of the red and black speaker terminals that would hook to the subs. So there is the outside of the box whgere you would connect the wires coming off the amp to the outside connection on the box, then there are the 4 connections on the inside that connect to each sub.
Sorry but im finiding it hard to explain
Old May 2, 2004 | 10:14 PM
Engine: 2.2
connect the red to red (+) and black to black (-)
this is a parallel connection. this is what you most likely need to do.
chances are the two subs are 4 ohms each, therefore they will be 2 ohms in parallel.
Old May 3, 2004 | 11:14 AM
2 dope's Avatar
Engine: 305 LG4
yes they are 4 ohms each,...... thankyou
CD MaroMan 91
Car Audio
Sep 1, 2001 12:27 PM
89Firebird Formula350
Car Audio
Aug 30, 2001 06:41 AM
TrueBlue91RS
Car Audio
Aug 18, 2001 11:58 PM
TrueBlue91RS
Car Audio
Aug 14, 2001 07:30 AM
Tom 400 CFI
Car Audio
Apr 29, 2001 01:48 PM
