How to bridge a rockford 800.4 amp
This is a lot to ask, but here it goes. How do you go about to bridge a 4 channel amp to a 2 channel? What is needed to do this? These are the specs of the 800.4 amp.
100 W X 4 @ 4 Ohms RMS @ 1% THD
200 W X 4 @ 2 Ohms RMS @ 1% THD
400 W X 2 @ 4 Ohms Bridged RMS
Total power 400 Watts RMS
I want to get 2 12" cerwin vega: vega series subs.
specs on 12" cerwin vega:vega series sub. (I have 2 of these)
76-400 watts rms
800 watts peak
200-500 hz frequency range
4 ohms
How can i bridge this amp to go with this setup? Or is there a better amp for this setup? Any help would be appreciated! Thanks!
76-400 watts rms
800 watts peak
4 ohms
all it takes is the instruction manual and a brain to comprehend it
. for real if you dont have the manual, all you have to do is look at the amp. i think it should say "bridged" and have arrows pointing to the correct terminals to connect your speaker wires to. you will take the negative from one channel, and the positive from the other. that will bridge them. you bridge the A's or front's together, and the B's or rear together. but the manual can make what i blunty described a little more sensible. hope i helped some .
. for real if you dont have the manual, all you have to do is look at the amp. i think it should say "bridged" and have arrows pointing to the correct terminals to connect your speaker wires to. you will take the negative from one channel, and the positive from the other. that will bridge them. you bridge the A's or front's together, and the B's or rear together. but the manual can make what i blunty described a little more sensible. hope i helped some . dude, get adobe acrobat reader, and go to www.rockfordfosgate.com , they have manuals for download and it tells you in the manuals...
<font face="Verdana, Arial" size="2">Originally posted by KlayBuRn:
dude, get adobe acrobat reader, and go to www.rockfordfosgate.com , they have manuals for download and it tells you in the manuals...</font>
raymondandretti
Sep 27, 2015 06:43 PM
