Hot Rockford Amp Question
Old May 6, 2004 | 07:00 PM
cbarry's Avatar
Hey, i got a problem with my rockford 300s. It was working fine then then cut out, came back on and then cut off. Now the light comes on but no sound. I want to get it fixed cause i love that amp. Any suggestion? Thank you!
Old May 7, 2004 | 08:09 AM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
To answer this, we will need to know a few things first.
What kind of set up are you running?
Are you running the amp at a low ohmage? (less than 2 ohms)
Do you have good power and ground wires? (preferred 4 guage)
Here are some common things that cause what you are experienceing..
- Power wire connected to remote connection on amp
- Bad grounds
- Bad power wire
- Issues with the deck's remote out.
- Sub voice coil dying
- Overheating due to improper mounting location
Hope this helps a bit.
:lala:
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
