Pioneer DEH-P3600 audio setup help
Car: 1991 Firebird
Engine: V6 3.1
Transmission: Automatic
was wondering if anyone owned one of there, just bought one the other day, and was messing with the settings, now i kinow how to install and what not, but i am still a newbie to the frequencies and setting and what not, most of my otehr head units had bass and treble settings, but this thing is loaded up with all sorts of crap, what i was wondering is how could i get it set up for minimal bass in the front and rear speakers, yet mucho bass to the subwoofers, if ne one else has any suggestions to premium sound setting on this thing lemme know, i got 2 pioneer kappa components up front and pioneer kappa 6x9's in the rear
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
there should be a high pass filter and a low pass filter.. these respectively control what goes where.. high pass controls what your highs see and low pass controls ur lows. set low around 125 or 100 and ur highs aroud 125 to the highest.. just play around and see what you like
Car: 88 Camaro
Engine: L98 350
About need a manual to set this up but it can be done. You need to turn on the subwoofer circuit. This will let you set the sub freq. separate from the radio speakers. Will have crossover freq. and level of boost for the sub only. Then you can use your standard controls for the regular speakers. Note that you'll have to have a a separate amp with RCA type cable from stereo to amp.
LT1Formula
Oct 8, 2015 08:34 PM
