Foam Batting???
Old Aug 11, 2004 | 10:47 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Foam Batting???
I was wondering. Why are people putting foam batting in their enclosures. What exactly does it do? I never did this to mine...is this something I should consider?
Old Aug 12, 2004 | 12:51 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Makes the sub think the box is bigger then it is by slowing down the wave.
Old Aug 13, 2004 | 10:24 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
makes deeper bass with smaller box... and bigger boxes are ALWAYS better in realistic applications
Old Aug 17, 2004 | 02:35 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I used dacron i think its called cant remeber though. Its like polyester fiber basicly made the bass sound cleaner when i put it in my sub box.
Old Aug 18, 2004 | 07:16 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
When using a sealed enclosure, stuffing the enclosure with poly fill can "fool" the sub into thinking that it's in an enclosure of up to 10% larger size.
In ported applications, you don't want to block the path between the back of the sub and the port, so most people just staple acoustic foam to the walls of the enclosure. This has very little effect at low frequencies, although it does help the sub think it's in an ever so slightly larger enclosure. Where the padding comes into play is generally to damp higher frequency resonances and standing waves, which is a benefit to your midrange performance in a full range speaker.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
777Shock777
Oct 29, 2015 04:30 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
J.C. Denton
Sep 21, 2015 04:23 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
