Help !! With stereo install
I purchased a used 1.5 din to install in my Trans am and when i went to install it both wiring harnesses have been cut. I have no idea how to install with out the connectors. Any idea where i can get a diagram or anybody local could help me out. Near Dayton
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Look around on www.the12volt.com . I believe they have what you're looking for.
Car: 88 Camaro
Engine: L98 350
What type head unit? Most auto stereo shops have the plugs for GM stereos and the kit will have a wiring conversion diagram. Around 20 bucks.
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
here you go
GM up to 1989-90
right rear spk - light blue
left rear speaker - yellow
right rear speaker-dark blue
left rear spk - brown
left front spk-tan
right front speaker-light green
left front speaker-light gray
right front spkr- dark green
power antenna- pink
12 volt ign wire yellow
headlight dimmer wire - gray
ground wire -black
12v battery wire -orange
typical new radio wire color
purple/black stripe
green with black stripe
purple
green
white
gray
white with black stripe
gray with black stripe
blue
red
orange
black
yellow
match above with the factory wire chart I posted ,they are all on order ,if your car has the 1989 and newer plug let me know.
GM up to 1989-90
left front spk-tan
power antenna- pink
ground wire -black
purple/black stripe
purple
green
white
gray
blue
red
orange
black
yellow
db057
Aug 11, 2015 10:11 PM
