Help! Orion XTR 275 making weird noises!!
Old Oct 11, 2004 | 08:26 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Does anyone have experience with these amps?! I can't find any info on them!!!
If you take the top cover off, you see many jumpers, and then 2 add-on boards with jumpers and switches. When I leave everything the way it is, and hook up a speaker, I get an ear-piercing BEEP constantly. Obviously I don't leave the speaker connected!
If I remove the add-on board with just 2 DIP switches on it, then I get a "pop pop pop pop" constant sound from the speakers. If I remove the add-on board with the jumpers, the amp works, but you have to put your ear right up to the speaker to hear anything.
SO, does anyone know how to set these jumpers? I swear that's the only problem!!
Also, is this amp even worth the effort? I'm not familliar with the brand!
Old Oct 11, 2004 | 11:43 PM
onebadwagon's Avatar
yeah, the old orion stuff is pretty good. i'd try to figure it out, if i where you.
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
BrianI
Aug 9, 2015 11:52 AM
