Radio wiring questions
Car: 1989 Iroc-Z
I pulled a four year old Alpine from my Iroc-Z and installed a cheap-azz Sanyo "Stealth" deck. What a mistake. The Sanyo distorts with funky feedback through the speakers before you can get it loud. So the Alpine is going back in.
First question:
Orange wire from Alpine deck labeled Illm
Wire harness from Iroc-Z has two connectors. One is a two pin connector with a yellow wire and an Orange wire. The orange wire is labeled Illumination. The 12 pin connector also has an orange wire that is labeled Dimmer. Should I use one of those or not ? Neither one was connected before and the Alpine worked fine.
Second question:
Are the OEM speakers 8ohm or 4ohm ? I'm thinking they are 4ohm and the Sanyo deck is for 8ohm speakers. The Alpine works with either one. The Alpine sounds great with the OEM speakers but it is very sensitive to lightly scratched CDs.
First question:
Second question:
Car: 1982 Camaro Z28
Engine: hot 355 ci small block
Transmission: built TH350
Re: Radio wiring questions
First question:
Second question:
First question:
Second question:
99% of OEM speakers (unless they are the upgraded Bose speakers - thats the 1%) are 4 ohms. I have never seen a 12-volt piece of electronics that wasn't meant for 4 ohms. You just got urself a crappy deck bud...btw, if the deck only wanted to see 8 ohms and you put 4 ohms on it (effectively double the load), you'd have already lost that deck....
bmoney
Car: 1989 Iroc-Z
Re: Re: Radio wiring questions
bmoney
bmoney
db057
Aug 11, 2015 10:11 PM
