Stereo install kit?
Old Oct 23, 2004 | 10:56 AM
phishfud's Avatar
Car: 88 GTA
Stereo install kit?
I bought an install kit from Circuit City for my 88 TA. I installed my Clarion just fine, and mounts ok, but I cannot get the bezel back on. The kit sits to high for the bezel to sit flush like it should. Anyone have a place that sells GOOD install kist where it all looks nice and somewhat factory when done? So much for the "universal" kit. any info would be great. Thanks.
Terry
Old Oct 23, 2004 | 11:23 AM
Nic's Avatar
Nic
Car: 1993 Ford Mustang
Engine: 5.0L
Which kit # did you use?
Old Oct 27, 2004 | 11:34 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Did your kit come with a ton of stuff in it? That's the typical fits all GM kit most places offer. If so, you're probably using the wrong one. You're probably not going to be able to get your new headunit to sit flush.
Old Oct 28, 2004 | 12:01 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
When you say "The kit sits to high" (BTW, it's "too high"), if you're literally saying it's high, like toward the windshield high, sometimes there is enough slack that if you loosen the screws holding the kit to the car, you can move it slightly and make it work.
If you mean it sticks outward toward the back of the car, then try what Gummie suggests.
Old Oct 28, 2004 | 01:37 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
slotting screw holes on install kits can work wonders.
Old Oct 28, 2004 | 03:54 PM
phishfud's Avatar
Car: 88 GTA
I meant that the whole thing, not the head unit is out too far, so my radio bezel cannot be put on. almost like the adapter is too large for the opening in the bezel. I'll have to look around in the big bag of stuff and see if i may have grabbed the wrong mounting tabs. I know it will not sit flush, but i hate not hvaing the bezel on, looks like crap. I didnt see any room to be slotting the holes, so maybe i did use a wrong part. Thanks for the info guys.
Terry
hectre13
Dec 11, 2023 08:14 AM
toronto formula
Nov 10, 2015 06:17 AM
hectre13
Aug 26, 2015 08:17 AM
drathaar907
Aug 6, 2015 04:20 PM
