I just installed new speakers & they whine like hell
Old Oct 27, 2004 | 09:54 AM
Alexcoqui's Avatar
Car: Trans Am "GTA"
I installed new Pionner speakers front & back & I Dinomated the area where they go, now Im geting a whine from them & it gets louder as I aselerate, so the fastest I go the more I hear it. Now about the same time I noticed that my battery gauge started go go crazy, I mean is not stead the alternator is still charging but the charge is not constant. Do you guys think that maby one thing has to do with the other. I didnt disconect the battery to do the speaker swap so Im thinking that maby I chort sircutied the alternator or something. Any opinions?
Old Oct 27, 2004 | 10:20 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
I doubt you killed the alternator when you were doing the install. I would check your grounds, it sounds like something is grounding out where it's not suposed to.
Old Oct 27, 2004 | 10:40 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
I agree with the grounds, but probably a bad ground, not a short to ground. Do anything under the hood? Do anything behind the radio? Or just replaced the speakers? It is possible the voltage problem is related. A bad ground under the hood (engine to chassis/batt to chassis) could make the dash gage give some goofy readings. Check the alt. voltage under the hood with a DMM.
Old Oct 28, 2004 | 04:55 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
I did Check the alt. voltage & is not steady, is still charging but the needle wont stand still.
Infested
May 22, 2018 11:56 PM
mhatfield 14
Oct 24, 2015 07:48 AM
89lsc
Aug 14, 2015 04:58 PM
