Power-Issues
Old Nov 13, 2004 | 03:02 AM
91RSHawaii's Avatar
Car: 1999 30th Anniversary Pontiac T/A
Power-Issues
Currently, all i have is stock speakers, but an aftermarket JVC deck that came with the car... strange thing though, is... when its on my voltmeter will move as in fluctuate to the beat of the music... what could be causing this? anyone have any idea? I'm hopeless when it comes to electrical.
Old Nov 13, 2004 | 02:11 PM
85_ZED28's Avatar
Car: '85 Z28
where are you connecting the meter?
Old Nov 14, 2004 | 01:58 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
I'm assuming it's the one built-in to the dash? and in that case, I'd go ahead and say that your deck either has a bad ground, or a bad power connection... check and see, but a lot of these newer decks actually need another power connection other than the one that comes through the harness.
Old Nov 15, 2004 | 02:44 AM
91RSHawaii's Avatar
so, definately deck related then? could this also be causing exessive heating?
Old Nov 15, 2004 | 04:16 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
it also wouldnt hurt to upgrade your ground wires under the hood...but i think your problem is the deck ground
Old Nov 15, 2004 | 03:12 PM
ScrapMaker's Avatar
well you'd know if it was heating, because you could easily try using the radio when the car and deck are both cold... does it still bounce?
Old Nov 15, 2004 | 07:52 PM
91RSHawaii's Avatar
well, my car has recently had an overheating problem, in which my left fan got melted to the housing.... so after i replaced it, i only had overheating problems w/ the radio on, not too sure, but it seems like the stereo prevents the fans from fully being effective. but yes, it always bounces.
91RSHawaii's Avatar
oh and i would have to take the deck out of the console to check the ground wire correct? im pretty ignorant when it comes to electrical.
Old Nov 16, 2004 | 01:03 PM
ScrapMaker's Avatar
yes you will have to take it out, and it should be the black wire on the harness...
I can't remember, but the yellow is the main power? I think there are two power inputs from the harness but now its been so long.
Old Nov 17, 2004 | 11:20 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Yellow is the constant hot to store radio presets, your clock, and various settings. Black is ground and red is hot from the ignition.
Old Nov 17, 2004 | 11:39 AM
ScrapMaker's Avatar
oh yeah that's right... but some radios even require a thicker guage power input that is separate from the harness... e.g. a lot of bluapunkt units require this
