Simple crossover question!
Old Dec 5, 2004 | 07:39 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ok, I have a pretty simple crossover... but I don't remember what wires go to what! Here's what I can tell you:
One wire comes from input and has just a connector on the end
One wire comes from input and has a 100v 3mfd cap on it
One wire comes from input and has a 100v 5mfd cap on it, and a small coil
I figure the one with nothing on it is the sub, but the other two I'm not sure! What one goes to the tweeter, and what one goes to the mid?
Old Dec 5, 2004 | 11:28 PM
9177's Avatar
the wire is probably for the sub, the one with a cap and an inductor (coil) is for a mid, the one with just the cap is for a tweet.
Old Dec 6, 2004 | 07:34 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
wow, that IS a simple crossover. A full range woofer, with a 1st order on the mid and tweeter with absolutely no impedance compensation or notch filters.
What kind of drivers are those? They must either have very smooth rolloff and impedance characteristics, or that's one **** poor crossover.
Old Dec 6, 2004 | 09:10 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
It's a MTX box that I found it a parts car. 2 12" subs, 2 5" mids, and two 2" tweets. I probably won't use it, but I wanted to clean it up and actually solder the connections (all were just crimped, and kinda loose!)
anesthes
42
Oct 24, 2015 07:30 PM
anesthes
Aug 24, 2015 08:18 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
