ok guys and gals, time to redo the system
Old Dec 16, 2004 | 02:55 AM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
Well its the winter and by next summer my car will be completley redone, engine, trans, rear, now hopefully the audio. Im selling my system to a friend to pick up some cash and looking into something new. Right now im runing 3x10" PolkGNX104's behind a Sony XM-DS1600P5 amp ( runs 900 wattsX1 @ 2ohms. ) This combo is really nice but just dosent do what i want it to.
Ive been looking into running two 12's. Ive had my eye on a set of AUDIOBAHN ALUM12Q subs:
120 oz. Double Stacked Strontium Magnets
Power Handling: 1000 watts R.M.S. 2000 watts Peak
Frequency Response: 18Hz 500Hz
Efficiency: 96.4dB
PHAT 1.75" EPDM Rubber Surround
Spun Aluminum Cone
3" 4-Layer ASV Voice Coil
Dual 6 Ohm
3 Ohm or 12 Ohm Operation
Now i wanted to know which amp will best suit running a pair of these. Is something like THIS going to be what i want? Would you sugjest something else? Help guy out. Calling all audio gurus.
Old Dec 16, 2004 | 08:32 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
you really want audiobahn? Dude, you can do so much better. There's stuff that gets louder if that's your thing, and there's DEFINATELY stuff that sounds way, way better for less money.
Likewise with the amp, there is plenty of stuff out there that actually makes power instead of just chrome plating their crap.
Old Dec 16, 2004 | 10:32 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
i dont wanna go against a mod but if you compare the numbers of most manufacturers i think (just base on numbers) that audiobahn is pretty good.
as far as amping those subs... id go with that amp.
Old Dec 16, 2004 | 01:29 PM
OutLaw305's Avatar
Well im up for opinions. Yes i want two, or maybe even three, 12's. Yes i want it loud and deep. Ok Jim, shoot.
Old Dec 16, 2004 | 02:50 PM
OutLaw305's Avatar
Heres a situation. If save up a little etxra cash i should be able to pick up two:
12" IMMORTAL Subwoofer, 2000w RMS, QUAD 2 ohm operation
12" Subwoofer
200 oz. Magnet Weight
2000 RMS Power Handling
23Hz - 700Hz Frequency Response
95dB Efficiency
3" QUAD 2 Ohms Voice Coil
8 5/8" Mounting Depth
10-7/8" Hole Cutout
...for about $450 which is really fine by me if they are the quality that they are supposed to be. Do you know anything about these? I do want the look, that is why ive been leaning towards audiobahn.
Old Dec 16, 2004 | 02:58 PM
Jim85IROC's Avatar
Bob, That's why you shouldn't compare numbers. I can find 200 cheap chinese woofers with numbers that look very impressive, but the subs are cheap pieces of crap that sound like a retard banging on a soup can for those 3 seconds before the driver fries itself with a 10 watt input.
Audiobahn is over-rated, overpriced chrome plated chinese crap. They are made to look nice and pound hard, and that's it. They have big voice coils and big magnets, so they do get loud and handle a lot of power, but most of them sound terrible, and dollar for dollar, won't give you the most SPL or even come close to giving you the best sound quality available. Anything in the same price range from RE, Adire, or a hundred other companies is going to give you a higher quality product as long as you don't mind sacrificing some of the chrome.
Secondly, there's nothing wrong with disagreeing with a Mod.
Outlaw, what's your total budget, and do you want SPL, sound quality, or a good mix of both? Also, what kind of music do you listen to?
Old Dec 16, 2004 | 03:37 PM
OutLaw305's Avatar
Well if there is something nice out there i want to know about it. Honestly, i listen to almost all rap, I would like to keep it under $1000 if possible. I would be leaning heavy on spl over sq, but i dont want to sacrifice so much sq that it sounds like crap.
Old Dec 16, 2004 | 09:39 PM
shortyjmg's Avatar
Car: 86 sport coup
Engine: 5.0
if you want something that will hit really hard kicker solo 15" L5or L7 it souds good on rap thats what i got . or Image Dynamics ID MAX 12 they poud really hard $400-449 a pop.
Old Dec 16, 2004 | 11:43 PM
OutLaw305's Avatar
I dont want to go the route of a 15. I was checkin out the Solobaric 12" L7 though, seems nice. Anyone got input on those?
Old Dec 17, 2004 | 12:04 AM
shortyjmg's Avatar
Car: 86 sport coup
Engine: 5.0
yeah the L7 12" will be more then enough. feed it 500watts and that should be very nice
Old Dec 17, 2004 | 12:10 AM
OutLaw305's Avatar
Ok ive decided that im going with Resonant Engineering XXX 12". I dont know if i want to go double or single though. How many CuFt are available in the well of the car? I will want to run it ported for sure. I will need 2.1 CuFt per sub at 28 Hz. How exactly would i tune the box to 28 Hz?
Also, any amp sugestions for running a single? Dual?
Old Dec 17, 2004 | 07:25 AM
Jim85IROC's Avatar
The XXX will pound like a bastard. Make sure you have a LOT of power for it. You're going to have to look into some of the class D 1,200 watt or bigger amps, and stay away from the no name crap that advertises 2,000 watts for under $200.
To tune 2.1 cubes to 28hz, you need a 4" round port that's 17 1/4" long, or you need to build a slot port. A slot port might be tough in an oddly shaped thirdgen box, although not impossible by any means.
Old Dec 17, 2004 | 10:42 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
well im glad that i posted that becuz i never thought of it that way....
MustangBeater20
Oct 29, 2022 09:20 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Feffman
Aug 13, 2015 07:11 AM
makaveli09
Aug 12, 2015 09:07 PM
