Battery Dies On Me ?
Old Dec 22, 2004 | 01:34 AM
DVL86's Avatar
Car: 85 Iroc-z
Engine: 5.0 V-8
I just installed a new sub in my car. My problem is that my car has died twice on me when I try to start it and I have had to jump start it. What could be causing my battery to die? Too much draw from the sub?? Im only running one 12'' infinity sub at 500 watts RMS or so. Thanks!
Old Dec 22, 2004 | 07:24 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Is the amps power light turning off when the car is off?
CaysE's Avatar
Did you wire the remote lead to an always-on power source? The amp would stay on all the time if you did, draining the battery.
Old Dec 22, 2004 | 02:38 PM
DVL86's Avatar
Car: 85 Iroc-z
Engine: 5.0 V-8
Yes; the green light on my class d amp does infact turn off when I turn the car off. I used the remote turn on wire from my head unit to also activate my amp and turn it off. Is there anything else I could do to check for problems? I dont think there could be a short because my sub works perfectly. Any suggestions? THANKS!
Old Dec 22, 2004 | 02:49 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Could be a lot of thing. Could just be the battery.
Got a DMM? See how much current is drawn from the batter when the car is off and let use know. Could also have to battery tested someplace, it's never a bad idea to check the simple problems first.
Old Dec 22, 2004 | 02:51 PM
DVL86's Avatar
Car: 85 Iroc-z
Engine: 5.0 V-8
OK I will check the current draw later today and post the results. Thanks.
Old Dec 23, 2004 | 06:24 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
ya your battery is prolly toast. My battery on my cutlass just died and it was under warranty. I actually got a better one in its place A system draws a decent amount of power. Its a good idea to have a strong battery/alternator when you have subs.
Nate
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
z28joe2
Sep 28, 2015 05:54 PM
Lmancha96
Sep 25, 2015 08:11 PM
lanceflame44
Sep 25, 2015 12:28 PM
