Need some help, sub and amp question
Old Dec 27, 2004 | 01:49 AM
DemonKnightDK's Avatar
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
Okay, i've tried searching here, google, and a few other places, and cant really find out how to do what I want to do.
I've got a lanzar vibe 900 amp, 900watts 4ohms ,ect.
Then I've got an 8ohm 15 inch sub (i've found 2 spec sheets, one says its 350 watts the other says 150. I'm going with the safe side and saying 150. probably 150 RMS 350 peak.)
my question, how could I wire this to work? how can make a 4 ohm amp put an 8ohm signal?
Old Dec 27, 2004 | 06:37 AM
9177's Avatar
You can't but theorectically the amp should be putting out 400-450 watts to the sub which should be plenty
Old Dec 27, 2004 | 08:06 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Re: Need some help, sub and amp question
if the sub has dual voice coils.. which i assume it doesnt. you could wire em in parallel to get a 4 ohm load.
the amp doesnt put out a 4ohm or any ohm signal. but the power that goes to the speaker depends on the ohms o resistance teh speaker shows the amp. so if your amp is 900watts RMS x1 at 4ohms id say you prolly have 450rms x1 at 8ohms which is still over powering that sub anyhows. be careful to set the gains and boosts low as to not blow the sub.
Old Dec 27, 2004 | 08:45 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
The biggest thing to keep in mind is not to go UNDER the rated load of the amp (for the most part). You'll have less power, but you wouldn't kill the amp.
Old Dec 28, 2004 | 12:14 AM
Car: 1985 Firebird
Okay, I'm not gonna mess with it. Any one want to buy an eminence beta 15 sub?
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
