MA audio amplifier
Old Feb 16, 2005 | 09:41 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
MA audio amplifier
I jsut got my new MA audio hk800d the other day and installed it. It worked fine for a day but then i started having troubles...its a mono amp and im running a 2 ohm load. While listening to the amp the LED will first light up blue...but only for a split second....then it either goes to red....or the LED turns off altogether. I looked things over real quick but im not sure exactl where look. i tried connecting the remote wire to a different 12v but there wasnt a difference. The amp fuses are all good. Any ideas on what to look for.
Old Feb 17, 2005 | 07:49 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Your amp is going into protect. Try disconnecting the speakers (with the amp off). If the amp still goes into protect, disconnect the RCA cables (with the amp off) and try again. Let use know what happens. DON'T just leave the amp on with load for more then a min. or 2.
Old Feb 17, 2005 | 08:14 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
prolly a bad ground.
SRKLEGIN
Oct 29, 2015 06:38 PM
L98GTA87
Oct 19, 2015 10:43 PM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
gta892000
Sep 16, 2015 12:37 AM
84 TA NV
Sep 6, 2015 08:02 PM
