broken back window
Old Mar 10, 2005 | 08:49 PM
midnightsun13's Avatar
broken back window
anyone every blow they're back window running a set of 12's? if so how many rms? thanks
rob
Old Mar 10, 2005 | 11:09 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
i think it would take a hell of alot somone at my school got a 15 with 2000rms in a 3000gt facing up and it dont break
Old Mar 10, 2005 | 11:26 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Yeah, if you search around, you will find other threads with people saying you wont shatter your glass.
Old Mar 11, 2005 | 09:18 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's physically impossible. That's the strongest piece of glass in your car, and even the weakest piece of glass (side windows) are substantially stronger than the tin panels and rubber gaskets that will give out first.
Old Mar 11, 2005 | 12:39 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Ditto. The hatch glass is so thick and it has a round'd shape. Not to mention I would be willing to bet the plastic housing for the pull down would be the weak link (it's plastic housing with 3 screws that hold the hatch firmly in place). After all people break them by slamming them hard.
I once had a local audio shop tell me they had a pair of 15s break a hatch off an f-body. My guess is the plastic housing was abused or they slammed it hard installing the setup. Then when it vibrated the hatch glass that was enough for the plastic housing to finish cracking and fall apart.
They continued to tell me my 18s with 1200 rms to each would probably blow the hatch and hinges completely off the car.
Going back to the rubber gaskets I did blow the the hatch seal one apart at the weak point right at the center where the hatch latch goes into the plastic trim.
The side windows let most of your pressure out anyways.
Old Mar 11, 2005 | 07:13 PM
thnks for rhe replies a friend of mine said he coult only install 10's because he would shatter his glass i told him i didnt think so but i was just makin sure
Old Mar 17, 2005 | 02:11 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
2 18"s? wow... I used to think 2 15"s were overkill... what did the box look like?
Old Mar 17, 2005 | 03:00 PM
Engine: 383 SBC
You've seen the post before. It's the 2 18"s with ~ 3.4 cubic feet of air each sealed in the well taking up the entire space (including some deleted trim) all fiberglass.
Old Mar 17, 2005 | 05:33 PM
ScrapMaker's Avatar
got a site for it?
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
pfsteichen
Feb 9, 2016 06:59 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
